Topic: Lenovo A690  (Read 5635 times)
Offline marculos
  • CPC 464
  • Kudos 8
Lenovo A690
« on: December 03, 2012, 01:52:31 PM »
After breaking I think my 15th work blackberry (of which only two were broken by me , rest faulty) my warranty finally ran out ! Decided to get cheap Lenovo android phone to match my Lenovo laptop :)
It was £70 from pandawill. This is my first android phone and so far it seeems like a great phone for the price.
Good Points
£70
Dual Core 1ghz CPU, Not so great GPU apparantly but seems ok so far to me
Nice, very responsive capacitive screen
Wifi / GPS / Bluetooth / G Sensor all work fine
Came with free 4gb SD card
Bad Points
Only 512mb internal memory, half taken up by OS. I have modified the device so that all apps should install to SD card, but a few so far will not installto SD card
Not rooted - not really sure whatthat means lol
So far have been unable to get google play to work, other app stores do though
Lots of chinese apps n stuff installed which I am not sure what they are or do
For the price its a great phone, in hindsight I  should have spent a few more quid and got one with a lot more internal memory
You fail it! Your skill is not enough, see you next time, bye-bye!
Offline muguk
  • Sarcastic Git plc!
  • Kudos 32
  • Mug U.K(tm)
    • Mike's Word Toolbox
Re: Lenovo A690
« Reply #1 on: December 03, 2012, 02:55:14 PM »
Not a phone I'm aware of or heard of but to really get under the phone's hood, rooting it is the first thing to attempt.  Titanium Backup (or whatever other backup solutions are out there) only *really* works once a phone is rooted.
You are currently prevented from seeing any of the system files until your phone is rooted.  Which is probably how the phone manufacturers / phone providers want it so that you can't debloat your phone from whatever 'freebies' they've thrown onto it.  Using something like ROM Toolbox, you can force uninstall these 'extras' if you're never going to use them. That would free up some of your previous 512MB.
Looking on XDA Developers forum for some help on rooting it and, if possible, extending the 512MB to something a little higher might make it a bit more useful apps-wise.
You cannot move every file to the SD.  System apps (i.e. the Google stuff) and the widgets must all run from the internal memory.  There are also, naturally, some apps which won't work at all from SD but the majority work quite happily.
Offline marculos
  • CPC 464
  • Kudos 8
Re: Lenovo A690
« Reply #2 on: December 03, 2012, 03:27:53 PM »
Thanks for the tips, appreciated. As far as I can see there isnt too much bloatwhere on there, it would be nice to have a really clean english Android OS with just all the native android apps, I need to see if there are any other custom Android firmwares available as I know one chinese company produces them.
I'm just hoping it will be more reliable than my previous blackberries !
Brand / Model
 Lenovo A690
CPU
 CPU: MTK6575 ARMv7 Cortex-A9 40nm 1.0GHz
GPU: PowerVR SGX531 Ultra
OS
 Android OS 2.3.6
 Memory
 RAM : 512MB / ROM : 512MB
MAX supports 32GB Class 12 Micro SD Memory Card (TF-Card)
Size
 124 x 65 x 11 mm
Weight
 134g with battery
Screen
 4.0" WVGA, 480 x 800, 16M Colors, TFT-LCD
Capacitive Multi Touch Screen
Network
 Dual Sim, supports W+G / G+G
2G?GSM/GPRS/EDGE: 900/1800/1900 MHz
3G?WCDMA/HSPA/HSPA+: 2100 MHz
SAR: 0.247W/kg
Color
 Black
GPS
 Built In GPS & A.GPS
Connection
Bluetooth with EDR & A2DP
Wi-Fi : vIEEE 802.11 b/g/n, supports Wi-Fi hotspot
micro USB 2.0
Camera
 Back 3.0 mega pixel / 2048x1536
Support to shoot 480P with sound, Max 30 mins.
Sensor
 Gravity Sensor, Proximity Sensor, Light Sensor
Radio
 FM
Video
 AVI, MP4, FLV, 3GP, MOV, ASF, MPEG, RMVB, H.263, H.264, etc.
Audio
 MP3, AAC, WAV, etc. / 3.5 mm Audio Jack
Special function
 G-sensor, P-Sensor, L-Sensor, FM radio, Wifi, GPS, Multi-touch, Dual SIM, Schedule Power on/off
Package Includes
 - Li-ion Batteries 1500mAh x 1
- Earphone / 3.5 mm Audio Jack
- USB Cable
- Charger
Offline muguk
  • Kudos 32
  • Mug U.K(tm)
Re: Lenovo A690
« Reply #3 on: December 03, 2012, 03:51:50 PM »
I had a quick sniff around XDA Developers and nothing jumped out via Google.  But with it running Gingerbread, I would guess it's about a year old, so a lack of anything available to give it a boost does surprise me somewhat.
But welcome to the wonderful world of Android :)
Offline billdooruk
  • Kudos 26
  • I could murder a curry
    • Our site:-
Re: Lenovo A690
« Reply #4 on: December 08, 2012, 10:39:47 AM »
If you do get it rooted I would recommend "Link2SD"
You have to create a partition on your SD and format it, the app them fools android into thinking it's part of the phones memory so it links the app to the SD card but the phone still thinks it is on internal memory...hope that makes sense ???
Offline marculos
  • CPC 464
  • Kudos 8
Re: Lenovo A690
« Reply #5 on: December 09, 2012, 09:30:16 AM »
Thanks for the tip I have seen LinktoSD but I can't root the phone as yet. I have managed to install all apps to SD card, it seems after installing a certain number apps it wont let you install any more though. There are a few apps I'd like to remove but don't think I can until its rooted.
Offline muguk
  • Kudos 32
  • Mug U.K(tm)
Re: Lenovo A690
« Reply #6 on: December 09, 2012, 10:48:10 AM »
According to this website here it is sold (by them) pre-rooted?
I'm guessing also that because this isn't really sold in the UK (under any other mobile phone shop brand, i.e. my old Orange San Francisco was really a rebadged ZTE Blade) that this could also explain the lack of interest in it.  I found lots of sites offering the same suite of rooting tools *but* no instructions (other than filenames) are in English.
« Last Edit: December 09, 2012, 11:21:59 AM by muguk »
Offline muguk
  • Kudos 32
  • Mug U.K(tm)
Re: Lenovo A690
« Reply #7 on: December 10, 2012, 12:43:10 PM »
This link seems to show that it might be possible to make your SD card memory be seen as part of the main phone's memory, giving you more space to play about with apps etc.
